Speaking of milage...the TORNADO???
Discussion in 'The Garage' started by hi pinion, Feb 26, 2005.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Does anyone use this thing? :D If so, does it work? Or is it just a giimck pos?:grin:
  2. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Another gimick, just like the electric supercharger/hairdryer
  3. hi pinion
    Sep 25, 2003
    5,354
    :grin: Doesnt it make a cool noise though? :grin: Like the card in the spokes trick??? Have you tried it? I had a customer swear by those things. Siad they kick ass.I dunno
  4. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    Did He Strap It To A Dyno Or Was It A Mental Hp Gain?
  5. AkMudr
    Dec 30, 2004
    917
    Alaska
    I havent personally tried it, I know better:D But I have seen enough people buy it to know its a joke.
  6. hi pinion
    Sep 25, 2003
    5,354
  7. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    Cyclones are cooler than tornados... :p:
  8. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    They actually DO work because they make the vehicle lighter.....specifically, they remove some of the weight from your wallet.
  9. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    A friend of mines dad put one in his Taurus. He swears up and down it increased his mileage. :p:
  10. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you should tell him that putting heluim in the tires will decrease the weight and help with milage alse :rotfl: :rotfl:
  11. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    The whole concept of the tornado goes against all logic in improving the performance of an engine. To make more power people spend lots of $$$ to straighten out the air flow. Velocity stacks, smooth straight cold air intake, porting heads,polishing FI intake runners Even K&N filters. All are proven Performance mods to straighten out the air flow and help give a clean non turbulent air/fuel mixture to the combustion chamber.
    Also many newer cars use an air stream straightner in front of the MAF sensor because MAFs work better when the air flow is clean and smooth.
    I dont see how a shiny bent up pice of sheet metal that causes a bunch of turbulence in the air flow could do anything but restrict the intake and kill performance.
    Maby at low RPM the thing would act like a carbeurator venturi and have a small effect in increasing the air velocity and could possibly give a little more torque on the low end. That effect may show a slight improvement in city gas milage if you drive like an old fart.
    But i think any real gains people see in the thing are from the " I spent 70 bucks for the thing and it works great".Effect
  12. undr8ed
    undr8ed Registered Member
    Feb 20, 2005
    17
    Spokane, WA
    Don't forget to rake the front end... That way you're always driving downhill :laugh:
  13. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Actually, turbulence isn't a bad thing at all. What is important is where it is, and isn't. Turbulence in the intake runners causes a thick boundary layer which effectively reduces the size of the runner. That's not so good. In a wet flow intake (TBI & Carb'd) you need some turbulence the whole length of the runner to keep all of the fuel suspended in the air. A polished port wall won't do this. When the fuel condenses out of the air and runs down the port floor as a liquid then power, drivability, and mileage all suffer.
    Turbulence at the point where the fuel is intro'd to the air is a good thing. Most late model heads are designed to produce turbulence at the intake valve pocket to better promote a homogeneous mixture. The more homogeneous the mixture is, the more efficient the burn and therefore the power the engine will make from a given amount of fuel.
    The whole point of Smokey's "Adiabatic Engine" (which it was NOT) was to better homogenize the fuel into the air. From what I've seen both at work and elsewhere, there is a huge amount of power going to waste due to lack of fuel/air charge homogenity. When the mixture approaches total homogenity it can actually ignite (detonate) at precisely the right time for best power and efficiency. The phenomenon is called "HCCI", Homogeneous Charge Compression Ignition. It's similar to the diesel cycle, but a LOT harder to do consistantly.
    I wouldn't buy a Tornado either.
  14. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    i would bet it does little to increase turbulence... but i'd bet a bunch that it restricts airflow... ;)
