special tool for idle screws?
Discussion in 'The Garage' started by vortec, May 5, 2005.
  1. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    quadrajet on an 82 350. i've had trouble trying to adjust the idle screws because i can't seem to find a tool that will fit them properly. the heads of the screws are flat on two sides and rounded on the other two. is there a tool made specifically for these? i can imagine something like a really big version of a valve core puller.
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    You're supposed to get a certain size of metal tubing ( can't remember which one) and pinch the end of it down till it fits. It just takes a short piece, then you can throw it in your glove box.
  3. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    Snap on makes one. I forgot the part number. They were the ones that Jet Performance gave me for the quadrajet I bought from them.
  4. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Go to a parts store and ask for a carb adjustment tool. For about $7 it is a screwdriver with a spings shaft and holds for bits in the handle to work on different styles. It will have the one you need and is very easy to use because the shaft is flexible.
  5. ratzila
    Aug 9, 2003
    691
    Mobile,Al
    I bought one of those and it did not have the correct bit. You can use tubing and bend one side flat as said before. I'll check on snap-on's site for the tool #
  6. poinzey
    poinzey 1/2 ton status
    Jun 16, 2004
    113
    Texas
    I got one of those kits from Autozone. It came with several tips to fit different apps.
    Check out the Lisle kit at the end of this page
    That's the one I used and worked fine. :)
  7. ratzila
    Aug 9, 2003
    691
    Mobile,Al
    I believe the snap-on part # is S6139. You can call Jet Performance to verify that is the one they use.
  8. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    i got 82 with 350, mine had the quadrajet when i bought it, but i have since replaced it, one thing to check is at first my adjustments were blocked off, so i had to remove the plugs, second i got a carb adjustment tool from napa, for about 10 bucks..
  9. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I prefer pliers my self :D
  10. smalltruckbigcid
    smalltruckbigcid 1/2 ton status
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    Its called a double D socket...another useless trivia fact taking up valuable brain space :laugh:
    George
  11. vortec
    Jul 22, 2004
    1,472
    fort worth, texas
    thanks for all the responses. i'll check on that tool to see if it has the right bit. if not, i have some old hvac copper tube left that i could try. those screws sure are hard to get to, especially on the passender side. a carb spacer would probably be a nice touch for making adjustment easier.
