Special tool needed to remove temp sendor plug?
Discussion in 'The Tool Shed' started by CK5, Mar 25, 2006.
  1. CK5
    May 19, 1999
    21,623
    701
    CO
    Is there a special tool needed to remove temp sendor plug on the passenger side of a 91 350? Looked like my 3/8 drive would fit in there but it's to big and the 1/4 drive is to small WTF.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Go buy a CHEAP Chinese 3/8's extension and massage the end with a grinder until it fits. The plug is ****in' metric on the later engines. :mad:
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Don't worry, they usually don't come out and you end up drilling them anyways. I know, not what you wanted to hear but it's the gods truth most of the time.
  4. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    Had the same problem but got mine out. Made a tool. Still got it tooooo....
  5. ryoken
    Jun 13, 2003
    29,622
    1,376
    Jersey Shore
    I keep a supply of different sized SS keyway stock in my box for that reason... Then I just use a female square drive socket of the appropriate size to drive it.. Wrench'd work too...
  6. CK5
    May 19, 1999
    21,623
    701
    CO
    Welp, ****ed it up because the plug wouldn't budge, then drilled it out to put in an easy out, then the craftsman easyout broke off flush with the block. :angry1: :angry1:
    So now it looks like I am going to cover it up with JB weld in hopes it lasts till this fall, then put in a new motor, I'm done with this leaky POS anyway. Don't need a temp gauge as they are only needed if you care about your engine which I don't.
  7. ryoken
    Jun 13, 2003
    29,622
    1,376
    Jersey Shore
    eesh, sorry to that.. Hope that holds for ya... But hey, I've seen guys JB Detroit blocks and they've held...
    Now thats funny... :haha:
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Take a large nut that is barely smaller than the plug and find a way to hold it solid/steady over the plug and broken ease-out. Then weld it like a roset weld, starting with welding the ease-out to the plug, then picking up the inside of the nut. Probalby have to take out inner fender, but it will almost certainly (every time in my experience) break the rust loose and the bolt/plug will come out. There is no other way to add heat that fast, and it shatters the oxide which can't handle the rapid change. Worst case, it's welded up and won't leak...
  9. CK5
    May 19, 1999
    21,623
    701
    CO
    Well, that shouldn't be a problem. :D
    I might try that in a few weeks, will be in the middle of moving soon. Wonder if it would be easier to weld a short bolt in there instead of a nut, might be able to hold the end of the bolt with a socket and weld around the threads, on 2nd thought, the leverage might snap it off again??
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Oh, is this on the truggy? Some reason I was thinking the Sub, do you even still have that?
    Anyway, problem with a bolt is that you can very easily arc over into the block and blow holes or weld the plug to the block, or effectively form something like a keyway that won't let it turn due to mechanical interference. The nut helps keep the arc constrained, and gives a much heavier weld than you would typically get around a bolt, not to mention less chance of twist off, just as you suggest.
  11. CK5
    May 19, 1999
    21,623
    701
    CO
    Good point, and yes, still have the Sub, need to list that for sale soon.
