Specialty Top Co's '73-'75 fastrac ???
Discussion in 'The Garage' started by 73k5blazer, May 15, 2005.
  1. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I used to have an old kayline top for my '73, it was the all snap version. It had a sweet feature where you could roll up the sides and back, but the roof section remained, for what I called "safari" mode. It had sewed in straps to contain the rolled up section.
    I can't find enough info on the newer fastrac model for the '73-75's. Can anyone tell me if the '73-'75 fastrac model has safari mode?
  2. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
    Yes, the one on my '74 does.
    You zip off the side panels and roll up the back window.
    All that is left is the top and a small corner section over each taillight.
    GrimReaper did a great writeup on the top somewhere on this site a while back. Don't remember if he showed it in "safari" mode.
    Hope that helps.
    -Ben
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Yeah, I was looking at the write-up, it didn't mention zipping out the sides or anything, and no pictures of it in safari mode. That's why I asked, and you answered. Thanks!
  4. seschev3
    seschev3 1/2 ton status
    Jan 19, 2005
    308
    clayton, ca
    I have had mine for 3 years now and always outside. They hold up pretty well with minimal leaks. In safari mode on the freeway, I had to add bungy cords between the 2 rear hoops to add tension because with the fastrac the rear corner flaps would come off.
