Specs on a 330hp/350 cam
Discussion in 'The Garage' started by Blaze, Dec 20, 2002.
  1. Blaze
    Blaze 1/2 ton status
    Aug 28, 2000
    3,285
    Raleigh, NC
    I have a cam sitting here out of a Chevy crate motor, the 350, 330 hp one. It only has 20k miles on it and I have the lifters, too. My 92 Yukon is starting to act up a little and I suspect it is the camshaft and timing chain. My wuestion is this, what gains would I get by going to this cam and a roller timing chain? I do mainly highway driving to and from work, but I also tow Trans Ams on almost every weekend. What do you guys think? /forums/images/graemlins/confused.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I suspect that the computer would throw a fit trying to figure out how to deal with that much cam, but I could be wrong. </font color>
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Specs For the new 350 HO crate engines:
    Horsepower: 330 hp @ 5,000 rpm
    Torque: 380 ft/lbs @ 3500 rpm
    Compression Ratio: 9.1 to 1
    Block: Cast Iron 4-bolt, 4.000" Bore
    Crankshaft: Cast Nodular, 3.480"
    Stroke
    Heads, Chamber Size: Vortec Cast
    Iron, 64cc Chamber
    Valves (I/E): 1.940"/1.500"
    Camshaft, Lift (I/E): 0.435"/0.460"
    Hydraulic
    Dur. @ 0.050" (I/E): 212/222
    degrees
    The cam has a little too much duration for a 92 TBI engine. The computer normally doesn't like durations over 212 degrees. 222 on the exhaust is a little high. It may affect idle and off the line performance.
    But you can get a new chip burned for that cam or a adjustable MAP sensor and it should work fine.
  4. Blaze
    Aug 28, 2000
    3,285
    Raleigh, NC
    So if I get a custom chip burned, you think it would be ok?
    Would you guys recomend this for towing or not?
  5. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Yeah should be Ok. Its pretty common to get chips burned for those HO 350s
    These guys know what they are doing:fastchip.com
    They probabally have one in stock for your needs.
    Also Check out:turbocity.com
    You will probabally want to modify your TB to flow better for that cam. They also are good at burning custom chips.
    I have delt with both of these people and have been happy with the results.
  6. Blaze
    Aug 28, 2000
    3,285
    Raleigh, NC
    Thanks! So you think it'll be fine for towing? I think I'm gonna do it. Once I get my 79 TA back I'm gonna do it and drive the TA around while the truck is being worked on.
  7. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    I'm not really sure. The 350HO has Vortec heads and that cam is probabally ground for them. The heads on your 92 are different. Bigger chambers, lower compression. 8.2 to 1 I think.
    But it is not that radical of a cam. And I'm sure you can get a chip burned to make it work for your needs. Call the people at the links I gave you. They should be able to give you some good info.
    Both have been pretty helpful on TBI engines I have built.
