Specs on a 91 3/4 ton sub
Discussion in 'The Garage' started by 84CUCV, Sep 10, 2005.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Has a 6.2 and a 700r4 and a 208. I thought it would be a 4l80e and 241. thanks for the help as always.
    mike
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    from the factory it should be a 6.2 a 4L80E and an NP241. 208s went away in 88 or 89 i do believe.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Either you have the year wrong, or somebody's messed with it. I'd run the VIN to be certain.
  4. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    Somethings not right. My '91 K2500 suburban had a 5.7L/4L80E/NP241 in it.
  5. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    I've *heard* that low-GVWR 3/4's had TH400's in '91 ... but I've NEVER heard of a 3/4 ANYTHING with a 700.
    You sure it's a 3/4?
    -- A
  6. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    My 2wd 3/4 ton has a th400 from the factory. Sure it's a 700r4?
  7. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Mine too, except mine is a V2500 ;)
    Eric M.
  8. Diesel Dan
    Feb 27, 2002
    798
    Warren, Ohio
    :doah:
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i've seen a couple of 84-87 K20/V2500s with a factory 700R4 when i was working at the dealership. my C2500 has a 4L60E which is the same as a 700R4.
  10. u2slow
    May 9, 2001
    2,217
    BC Canada
    In the event there was a low GVWR V2500 Burb, that would explain the TH700 trans. The kicker is with the 208 t-case.... it doesn't have a VSS like the NP241. So if the t-case got replaced, that would mean the speedo was swapped to a mechanical-drive version at the same time. :thinking:
  11. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Checked the vin. Someone messed with it. think i am going to pass on it now..... damn, cant seam to find a 91 with a diesel.
    thx mike
