Speed and gears
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BillR, May 16, 2000.
  1. BillR
    BillR 1/2 ton status
    Mar 15, 2000
    164
    Flagstaff, AZ
    I know you guys can help on this. I want to figure out my axle ratios. I have a TH-350, 31x10.50 tires, and a 203. Today on the interstate at 80 mph, I was running about 3100 rpm.
    I saw a formula somewhere for this equation. Do any of you know it or can point the way to it?
    Thanks in advance!
    Blazin' in Flagstaff
  2. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    The formula is RPM/(336/Tire diam x MPH)=Ratio rear end.
    This will work with any tranny that has a final drive of 1:1.Do the calculation in () first.Save this number then divide the rpms by this number.I get 3.57 so it should be a 3.55 gear set.
  3. K5Junkie
    K5Junkie 1/2 ton status
    Mar 29, 2000
    499
    Gulfport, MS
  4. Gold Rush
    Gold Rush 1/2 ton status
    1,498
  5. BillR
    Mar 15, 2000
    164
    Flagstaff, AZ
    Thanks much!
