speed bleeders
Discussion in 'The Garage' started by JohnDeere, Oct 3, 2006.
  1. JohnDeere
    JohnDeere 1/2 ton status
    Jan 17, 2006
    342
    Houston, Texas
    what size speed bleeders do i need for a 85 k5 with 10 bolts
  2. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    I got mine at pepboys in the help section. part number is 12702. The thread size is M10x1.5 overall length:33mm
  3. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Got mine the same place----the book will tell you what you need if different.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    how exactly do those things work? how does one go about bleeding brakes with them?
  5. poolcues
    poolcues 1/2 ton status
    Dec 13, 2004
    232
    Charlotte,NC
    they're used by cracking them open and pumping the brake pedal like normal. the spring loaded ball bearing prevents air from going back in. basically each pedal push expels air and the ball bearing prevents it from entering.
  6. JohnDeere
    Jan 17, 2006
    342
    Houston, Texas
    thanks guys i finally drove my k5 for the first time in 2 mounths and $1000 dollars later. yeah the speed bleeders work great. i had taken the orig out and lost them so i didnt have one to compare size. But i love my new rearend just got to break it in so i can really play with it. o yeah and put the rear shocks on. went over some rail road tracks and the back tires bounced off the ground a couple times.
  7. sunnyc123abc
    Mar 12, 2005
    636
    SoCal
    here http://www.speedbleeder.com/
  8. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    its basically a check valve
