Speed gear question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Eric M., Dec 18, 2003.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Anyone know if they make a speedo gear for the Turbo 400 with more than 45 teeth (45 tooth gear is light green in color). I don't want to install one of the ratio adaptors if I can avoid it.
    Thanks,
    Eric M.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i just checked the most they make for anything it 45 teeth
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Is this for a 2WD? 4WD's pickup the speedo drive from the t-case output. /forums/images/graemlins/cool.gif
  4. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Yeah, I was hoping to sneek in a question about a 2wd without anyone ratting on me!! /forums/images/graemlins/wink.gif
    Eric M.
  5. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Thanks TJ .... I was afraid of that.
    Eric M.
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Just checkin'! /forums/images/graemlins/wink.gif Didn't want to see ya buy a speedo gear for a Turbo 400 and then crawl under your truck and find out that there was no place to install it. /forums/images/graemlins/shocked.gif
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    doesnt have to be certain model you can use other model speedo gears too, i might have one with more than 45 if you know what exactly you need ?
    there is a formula for determining what you need, also you can drive from one milemarker on freeway to the next at 60mph with stopwatch and see if you are going faster or slower than 60 then you wil know what you need to do with gearset you have right now.
    go to google.com and type in speedo gear calibration in the search engine line
  8. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Hey Randy,
    If you've got a 46 or 47 tooth gear, that is what I need.
    Thanks,
    Eric M.
