Speed sensor
Discussion in 'The Garage' started by fparker, Jul 22, 2005.
  1. fparker
    fparker Newbie
    Jul 22, 2005
    Jacksonville, Fl.
    I need to find out what pulse output speed sensor to use on my 1990 Burban,
    I am running the TBI and ECM. The drive train is from a 1984- TH400 with 208 transfer case.
    What does the stock 3/4 Ton 90 model use for driving the ECM? Can I buy one off of the shelf to plug into my speedometer gear in the transfer case?
  2. eagle mark
    eagle mark 1/2 ton status
    Nov 18, 2004
    3,289
    North Idaho!
    You can program the VSS out of the chip and not use it on TBI!
    AFI does sell a VSS to hook up to the speedometer drive. I do not know what the pulse is, if you must know call the shop and ask for Norm. But a chip would be cheaper than a VSS and you can get rid of other things as well with it.
  3. dyeager535
    26,980
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    You can get a VSS from: turbocity.com They are at the bottom of the page.
    Or get a chip programed as said above. So you can dump the torque convertor loc up and egr .Wont really need those with the swap.
    Not sure if you can get a chip burned for less than $100
    maby someone will give you a deal just to disable what you dont need.
    Its not really hard to do.
  5. eagle mark
    Nov 18, 2004
    3,289
    North Idaho!
    Affordable Fuel Injection chips are $95.
    Also look in the vendor section for a CK5 discount! :D
  6. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    the 90 has a DRAC, so to make your speedo work, you need to input 40 pulse per driveshaft revolution
