Speed Sensor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by along4, Jul 11, 2002.
  1. along4
    along4 Registered Member
    Jan 1, 2002
    25
    Prescott, AZ
    /forums/images/icons/confused.gif I have a transfer case from a 90 K5, and do not know if it takes a manual or electronic speedo sender. The case will be put into a 1991 K5, so it will need to have the electronic one. I have heard it both ways, so I need a way to check. Thanks for any input on this.
  2. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    not sure, my 89 suburban has a manual one.
  3. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
  4. along4
    Jan 1, 2002
    25
    Prescott, AZ
    Is there any way to check to be sure?
  5. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    I have a '90 case that has the electronic type, are you asking how to visually tell the difference? on the tailshaft extension, where the rear drive shaft slides in, an electronic speed sensor will have a two wire plug for the sensor wire to plug into, the sensor will be threaded into the extension housing, a manual speedo drive will have a threaded sleeve with a square hole in the center for the speedo cable to screw onto at the same place in the extension housing
