speed wobbles
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MilpitasK5, Mar 5, 2002.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    Hello folks! It's been a while since I've posted. I picked up a TJ to be my reliable while I turn out my K5. Ended up having to do work on that!
    Anyway, I've missed this site! Here goes...
    I get major wobbles when I hit speeds between 25 and 35 mph. It feels like it might be coming from the right side. I also have a bit of a shake when I turn right. Does this sound like a bad U joint in the axle (not the drive shaft). The only reason why I think it's in the axle is because I recently changed the U joint in the drive shaft.
    Here is another one off the topic. I have a 3 inch lift front and 3.5 back. Do I need a drop pitman arm?
    86' K5 blazer
    3 inch lift
    w/ rust problems
    Thanks!!
    Chris
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Mark the tire with some chaulk then rotate the tires and see if it still happens. If its just the tire then have it checked out.....I would go with a steering arm block or dropped pitman arm.
    /forums/images/icons/smile.gif Now get outta heeeeh ya heeper........./forums/images/icons/laugh.gif
  3. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Damn! I knew I should have kept the Jeep thing to my self! I'm trying to sell it already. I originally was looking for a commuter car (Subaru) but that TJ came up for real cheap. Got suckered!
    Anyhow, thanks for the tip!
