Speedo adjustment?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by horsepit, Jan 18, 2002.
  1. horsepit
    horsepit Registered Member
    Nov 25, 2001
    63
    Ventura, CA
    Is there a bolt on adapter to correct my speedometer. I seems about 5 MPH slow now.
    1987 Blazer, 350, TH700R4, NP208, 3.42, Rancho 4", 33"
  2. Tatman
    Tatman Registered Member
    Oct 2, 2001
    80
    Indiana
    I have the same problem, my speedo shows @42 when I'm doing 55. I've gotten use to it and just figure I'm doing @ 10mph faster than the speedo until I can figure out a way to get mine set. Then if I decide on a larger tire size I'll have to do it all over again.
    Brian
    <a target="_blank" href=http://www.saddletramps.com/BlazerK5.htm>www.saddletramps.com/BlazerK5.htm</a>
  3. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    I have been told that the Chevy Dealers have the gears to correct for larger tires but i haven't looked into it.
    91K5 350 2.5in Suspension lift 33/12.5
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Just change the spedo drive gear.You can get a different gear from the dealer or from a spedo shop. The gear you need to replace is in the x-fer case where the spedo cable attaches to it. It is a easy swap. Just take off the keeper and it comes right out.
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze> Blazer pics</a>
    <font color=blue>Nevada... Where the pavement ends and the west begins
  5. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    How do you know what gear you need to go in there?
