speedo bouncing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by eastcoastk5, Sep 6, 2001.
  1. eastcoastk5
    eastcoastk5 Registered Member
    Aug 27, 2001
    24
    Beaufort SC
    My speedometer bounces from start until about 50 mph or so then its fine, any fix for this problem?
    america rises and sleeps under the blanket of protection that we provide.
    Col Jessup, usmc (A Few Good Men)
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    I think I remember reading that lubing the speedo cable will take care of this. Sounds like it is binding.
  3. slider79blazer
    slider79blazer 1/2 ton status
    Mar 23, 2001
    164
    littleton,co.
    mine does this also just unscrew it at the tranny and pull the cable out. put some grease on your fingers and smear it on the cable as you push it back into the caseing. I do it about once every 2 months. hope this helped.[​IMG]
    <font color=blue>whats a 4 letter word for farm wagon?-- ford</font color=blue> [​IMG]
    <a target="_blank" href=http://community.webshots.com/user/slider79blazer>http://community.webshots.com/user/slider79blazer</a>
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  5. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Check to see if the gear is starting to strip out also. Then you'll need to replace the cable.
    1984 K-5
    4" lift
    35x12.5 MTs
    buildin a 400 for it, any info greatly appreciated
  6. dyeager535
    26,980
    Pull cable. Holding the cable sheathing with one hand, (so the speedo cable makes "U") and the speedo cable with the other hand, spin it. If the sheathing "flops around" then the cable itself is bad. You can always lube the cable (not graphite lube) but the speedo itself can be bad.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
