Speedo Cable/Transfer Case leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tkjimmy, Jan 19, 2001.
  1. tkjimmy
    tkjimmy Registered Member
    Sep 21, 2000
    41
    Washington State
    OK, here is the deal. I have a pretty steady leak coming from around my speedo cable where it screws on to my transfer case. I have the NP241 transfer case. Why is there tranny fluid passing through to the cable? I am at a loss, and how might I go about fixing this? Any help would be great. Thanks.
    tkjimmy--Wa. State
    http://tkjimmy.coloradok5.com
  2. James
    James 1/2 ton status
    Jun 22, 2000
    179
    Castaic, Ca
    I had an np203 was leaking out of the speedo cable. Originally thought it was overfilled, wasn't though. I just put a rubber o-ring over the cable part yet inside the scew on cap. Did the job. You can get the orings at Autozone
  3. djohnsn
    djohnsn 1/2 ton status
    327
    Plano, Texas
    I don't know if this will help because I don't know how the NP241 is set-up, but I had the same problem on my NP205. It was solved by replacing the fitting that screws into the transfer case where the speedometer cable attaches. The replacement part had a seal in it that the original did not.
  4. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    thats the fix ! Check and see if there a seal and if there is replace it. early 203s and 205 did not have the seal and leaked.
    I understand the jeep thing I drive a BLAZER!!
    Ken
  5. tkjimmy
    Sep 21, 2000
    41
    Washington State
    Thanks for all the info guys. I went to GM, and they had an inner seal that is not included with stock. I will be doing it this evening. Thanks.
    tkjimmy--Wa. State
  6. 1Blazin71
    1Blazin71 1/2 ton status
    Aug 23, 2000
    112
    Los Angeles
    I have the same problem with my 205. I had the guys that put the 700R in check that speedo cable seal and they assured me that they sealed it up. Apparently they used silicone which isnt holding up now, or they just plain lied.
    I saw a similar post about this a while back which suggested that the vent tube might be clogged, causing pressure to build up and force gear oil past the speedo connector. In looking at mine tonight I cant seem to find any vent tube! There are a couple of holes on the top passenger side of the case which "feel" like they might take a vent tube, but I havent gotten a mirror out to get a look at them.
    Does anyone know of any pics of the 205 which would help me see where the vent tube is supposed to be?
    Also, do you happen to know the part # of the seal from GM?
    Matthew Meyer
    matthewm@inhollywood.com
    '71 K5 - 4" Lift 35"s
    ZZ4 350 - 700R
