Speedo Cable / Transfer Case
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by swamp donkey, Mar 10, 2003.
  1. swamp donkey
    swamp donkey 1/2 ton status
    Apr 29, 2002
    186
    Thousand Oaks, CA
    I am almost done getting her ready to sell /forums/images/graemlins/frown.gif One of the last things to do is hook up the speedo cable.
    When I put in my new transfer case we ran out of time and I had to leave 95% done. I noticed the next morning it was leaking so I lokked around and saw a HUGE hole near the top, facing the passenger side. I assumed this is where we were supposed to put the speedo cable. I ran down to the harwear store and got a pvc plug that I threaded in to stop dirt from getting in. That was 3 months ago.
    I just bought a new speedo cable from chevy duty, hooked it up behind the dash and started to run it down to the transfer case. When I got there I had to scratch my head and wonder... huh?
    The cable has a femal "nut" if you will that is supposed to thread on to something male. But the transfer case is also female. I stuck my finger inside the transfer case, and can't imagin how that little stick poking out of my speedo cable is going to touch anything inside there.
    I assume that there is some sort of assymbly that I am supposed to haveto mate the two.
    True?
    Oh yeah, and I put up some NEW PICTURES make sure you check out the slide show, it is only 1.4 Mbs and it shows the new interior parts.I can't belive I am selling this truck... sigh.
  2. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    There are parts missing. At minimum, you should have a driven gear, a driven gear housing, and a driven gear seal. If you have 3.07:1 gears, you should also have a ratio adapter box (1.2020:1 overdrive). Inside of the transfer case, attached to the output shaft, you must also have a speedometer drive gear.
    The output hole for the speedometer driven gear housing should point out of the *driver's* side of the transfer case.
  3. swamp donkey
    Apr 29, 2002
    186
    Thousand Oaks, CA
    Driver's side? didn't even look there! What it the big hole on the passenger side, near the top?
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Steve I've seen them on both side of a TC. Allthough most chevys have them on the drivers side.
  5. Kev71
    Kev71 Registered Member
    May 6, 2002
    45
    Roswell, Georgia
    Quick, kind of unrelated question: How are those tires holding up? First time i saw them on your truck, which is strikingly identical to mine, i was in love with the tires. However, i talked to some guys and they said the tires weren't all that good and even heard of horror stories about chunks of the tires just flyin off. Nonetheless, after seeing the new pictures of your truck, i want the tires even more and would like to know ur opinon. Plus, hows the rub with the 35s?, because i think we have the same lift
  6. Kev71
    May 6, 2002
    45
    Roswell, Georgia
    Oh man, and sweet tunes on the slide show. I dig, I dig.... /forums/images/graemlins/ears.gif /forums/images/graemlins/thumb.gif
