Speedo cable won't hook up to gauges. WTF!!!!!!!!!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Okiemuddog, Mar 23, 2003.
  1. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Speedo cable won\'t hook up to gauges. WTF!!!!!!!!!!!!!!
    I went to put my dash back together today for the first time since I bought my K5. All went well till the speedo cable, I went to hook to the speedo and no go. The ends on my cable has screw ends on it and the speedo has a little clip that looks like it slides over the casing. Do I have the wrong cable housing? I assume this is the correct cable for the truck, but again this is the first time I had tried to put this back together. My clip is too short to reach the cable from the mounting head of the back of the speedo. Any suggestions would be nice, this has me really frustrated. /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
  2. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    Re: Speedo cable won\'t hook up to gauges. WTF!!!!!!!!!!!!!!
    the end that goes into the cab should not have a "screw in end" it has more of a flare on it with a rib that will snap into place on the clip on the back of the cluster housing. I hope that made since, Basically it sounds like you need a new speedo cable
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Early trucks had the screw-on type connection, but I'm not sure what year they changed. Sounds like yours has either the wrong year cable or the wrong year speedo. I've got a clip-on style speedo cable from an '88 Blazer I could send ya for $10 plus shipping. /forums/images/graemlins/cool.gif I'm pretty sure that the end at the t-case stayed the same over the years. If you want this one, measure the total length of yours so we can be sure this one is long enough for your setup.
  4. monte0172
    monte0172 1/2 ton status
    Sep 16, 2002
    182
    Memphis, TN
    Dude you got the cable that goes to the Cruise control. You need the cable that is w/out cruise control.
  5. Okiemuddog
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Holy Sh*&, DUH! /forums/images/graemlins/eek.gif I should have thought of that, I forgot that this truck originally had cruise. I am not putting the cruise back in so I didn't think about having 2 cables. /forums/images/graemlins/rolleyes.gif
    Thanks Monte, off to the parts store I go.
