speedo calibration for gear swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88blueK5, May 14, 2005.
  1. 88blueK5
    88blueK5 Newbie
    Mar 22, 2005
    Hernando, MS
    i just swapped in 4:56 gears in my 1988 k5 w 700R4 & 33" tires, anyone know how i go about getting my speedo back to normal or close to normal??
  2. trailblazer86
    trailblazer86 1/2 ton status
    May 16, 2004
    112
    North Shore of Lake Ontario
    Send me your e-mail I have the formulae that you are looking for.
  3. trailblazer86
    May 16, 2004
    112
    Speedo Gear Calculator
    Try this link. It is a great speedo calculator.
    Chances are that your drive gear has 15 teeth.
    Now how to get the dealer to work on this is another Question. You may need to purchase a few gears to get the speed right on.
    A GPS is great for checking your speedo.
  4. jacksprat1599
    jacksprat1599 Registered Member
    Dec 13, 2003
    99
    Austin Tx
    are thes gears difficult to change?Is it a DYI mod.
  5. trailblazer86
    May 16, 2004
    112
    This is a very easy repair/mod.
    The only thing that may give you any trouble is the unit that holds the gear.
    (I can't remember what it is called. Brain fart I guess).
    Sometimes you will have to buy a different holder. This is also very easy and straight forward to replace. The parts person should know what you are talking about.
    Just figure out what gear you need. This will let you know what holder you need. The installation is straight forward.
    Be carefull and you won't even get any fluid on your fingers.
  6. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    Check out bowtie overdrive They've got the calculator and the gears.
    Rick
    P.S. My '88 had 3.42's in it originally and I've got the same setup as you now, and my speedo is about 15 mph faster than my actual speed right now.
