Speedo Calibration
Discussion in 'The Garage' started by tch777, Nov 10, 2004.
  1. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    Okay I have a 91 /forums/images/graemlins/burb.gif. Supposed to be electric speedo right? The guy at the diff shop said he couldn't find the DRAC to calibrate for the 4.56 and 33 inch tires.
    Where is it located and what am I looking for?
    I want to get the speedo correct as I can.
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    you will have to change out the speedo gear in the t-case.
  3. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    You know, you have been giving some people some off the wall answers lately. /forums/images/graemlins/screwy.gif Maybe you should stick to just reading around here. /forums/images/graemlins/rolleyes.gif There is no gear to change on the 90-91 K5. All electronic.
    I am not sure where the DRAC is, but here is a site that explains how to calibrate yourself: DRAC recalibrate . I thought I had another link saved for more information, but can't seem to find it.
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    ow sorry I didnt see the electric speedo part, my mistake.
    BTW the only other post I have made that was incorrect was the new wheel on the 14bff thing /forums/images/graemlins/rolleyes.gif
  5. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    Here is a better site, made by a CK5 member no less! (K5Chris). I just did this on my 90 and super easy to do...if you can handle a soldering iron you can do this yourself....don't pay someone to do it. As it says on the site the DRAC is located behind the lower part of the dash near the steering column in a white box. mine was directly underneath the stereo
    SITE /forums/images/graemlins/thumb.gif
  6. tch777
    Jan 15, 2003
    244
    Thanks guys the sites lay it all out so even I think I can do it. This is going to be sweet a Speedo that reads correct! Yes
    And as I read this I could just solder in the correct wire jumpers and do the same thing as the DIP switch, I just couldn't adjust for new tires as easy as the switch.
    Tim
  7. Sidepipes
    Sidepipes 1/2 ton status
    Nov 9, 2002
    139
    St. Thomas, Ontario, Canada
    I just installed/ removed jumpers on my DRAC. It works great... but the DIP switch idea is way better!
    It only took me an hour to do too.
