Speedo Correct? - ELectronic
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by woody9, Jun 18, 2001.
  1. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    You guys seem to have all the answers one could ever wish for, so let me toss one out.
    Just put a 14 bolt FF 4:10 eaton under my trusty Chevy, but.. seems the speedo is now 20% off (had 3:54 gears before).
    When I went to see what color gear I had in the x-fer case, it wasn't a gear, but a sensor! electronic speedo!
    Does this require DEALERSHIP REPROGRAM (boo hiss!!!) or is there somewhere else a tweak can be made?
    Thanks!
  2. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I believe your truck's speedo and odometer and that can be reprogrammed w/ one of Superlift's VSS chips... or something like that... maybe do a search on the offroad.com board... lots of IFS guys there w/ newer rigs. Or else you could check in w/ Superlift about it. One place I found that also may be of help is here...
    http://www.geocities.com/milnerlives_2000/blazer.htm
  3. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    I would go with the Superlift VSS correction device. Its one bad little toy. No matter what tire/gear combo you ever change to again you can reset it and not have to dig underneath your rig to do it. I think they run about 169.99 at <A target="_blank" HREF=http://www.tyres1.com>http://www.tyres1.com</A>
  4. fr8train
    Aug 2, 2000
    1,712
    Maryland
    One other trick is to go with a VDO unit with a calibrateable speedo. Solowookie has one in his truck.
