speedo eratic does it effect cruise control?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RESTORE89, Feb 28, 2002.
  1. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    my speedometer is 10 mph over actual speed and the needle fluctuates from 1-3 mph. will this make my cruise control surge?, or do i have a cruise problem?
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  2. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i know mine runs off engine vacuum, and i think the tbi does too, so no it shouldnt matter
    beligerence doesn't justify intelligence.
    <font color=blue>wheelers hate posers.</font color=blue>
    <font color=red>79k15/400/700r4/205/38.5</font color=red>
  3. dyeager535
    26,982
    191
    When the cruise went electric, (early to mid 80's on trucks IIRC) I'm 99% sure that VSS was integrated, so yes, cruise is affected by a bouncy speedo. (cable) Vacuum was still used however, but just to hold the throttle position.
    Dorian
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  4. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Yes, the bouncing needle will. The speedo error will not.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Yes it will.The cruise on My 89 surged real bad espically on a cold morning I had about a 5 mph fluctuation. I took out the spedo cable, cleaned and lubed it up good. That stopped the bouncing spedo needle and the surging also stopped. Cruise works great now.
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze> Blazer pics</a>
    <font color=blue>Nevada... Where the pavement ends and the west begins
