Speedo gear change
Discussion in 'The Garage' started by Muddytazz, Feb 18, 2003.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Does antone know how to change the speedo drive gear in a NP203 t-case? Do I just undo the cable and pull the gear out or do I have to take the tail end off the t-case to do this? Is this all I have to change to correct my speedo? Also, where do I get a new one?
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    What t-case?
  3. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    On the 205, you take the speedo cable off and take of the nut that retains the speedo gear, then the entire deal slide out...I think it is the same on a 208....you can also get a gear box to correct the speed and change the gears internally on that...Also, on the 205, the retaining nut for the speedo gear acts as its outer bearing (or bushing?)...Easy stuff though...
    Chris
  4. purple76pearl
    purple76pearl 1/2 ton status
    Jan 13, 2003
    450
    missouri
    would it be ok if i stepped in and asked the same question about my 203? dont want to impose just wondering? im like 15 miels an hour off, and dont know where to get the gear or how to even fix it
  5. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I would ASSUME that the 203 has a similar system...not sure though...the only 203 I have I have NEVER messed with and it is in a project truck in the garage...I will check it out when I get a chance...
    Chris
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Doh, I knew I was forgetting something...I'm working on a fulltime 203 /forums/images/graemlins/grin.gif
  7. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    you can get a gear with less teeth at the dealer but it wont work im not sure how you change it to make the correction for your speedo i think you have to ghange the gear that the speedo gear runs on also
  8. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Anyone else?
