Speedo gear change
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jcg, Mar 28, 2000.
  1. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I put 33's on last november and I'm finally getting around to changing the speedo gear. The only problem is that I can't get the d#*@ thing out! I took the cable off the plate but I can't get the plate out of the housing. Does it unscrew or just pry out? I didn't want to force anything till I got some advice. Thanks
    Joe
    88 Jimmy
  2. 89Jimmy
    89Jimmy 1/2 ton status
    192
    Northern N.Y. east end of Lake Ontario
    On my '89 it just pulls out after the keeper is removed. I left the cable attatched to give more leverage when I pulled mine. hope this helps.
    John
  3. mrkay
    mrkay Registered Member
    Mar 21, 2000
    44
    Plymouth, Ma.
    Joe...I just ordered 33" A/T's for my 88 Blazer. I have 31's on her now and the speedo is running faster than it should. I suspected that she had 32's or 33's on before I bought her a couple of weeks ago.
    Can you buy the speedo gears at a parts shop based on revs per minute from the tire specs? Also what speed do you have to be going to get that rpm figure?
    mrkay
  4. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    That's what I figured but I didn't want to force anything. It was about 7pm and I wasn't in the mood to fix a stupid mistake if I broke something. Thanks for the help.
    Joe
    88 Jimmy
  5. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I'm getting my new gear from my local GM dealership. If you know how far off your speedo is, you can take your existing gear out and count the teeth and note what color it is. The guys in the parts dept here told me that each tooth on the gear counts as 2mph so you just add or subtract teeth accordingly, they didn't tell me at what speed though... for some reason I didn't think to ask. I'll let you know when I find out, or if anyone else knows...?
    Joe
    88 Jimmy
