speedo gear ?
Discussion in 'The Garage' started by aj_tatted, Jan 11, 2004.
  1. aj_tatted
    aj_tatted 1/2 ton status
    Sep 6, 2003
    183
    arlington, tx
    o.k, how do you pop the speedo gear out on a 208. i know you have to take the bolt out and the clip comes off. but then what? i can't get that thing out for anything.is there some trick i'm missing? /forums/images/graemlins/rolleyes.gif
  2. dyeager535
    26,979
    If it's anything like some GM trannies (TH350, TH400, 700 and 200's) with the "large diameter" driven gear housing, I just grasp it where the cable threads on, and rock it back and forth, pulling outward. I think it is, I pulled one awhile back just to check it out.
    Rotating it is a no-no, apparently (at least on some) the driven gear is offset in the housing, and rotating the housing will screw the gears up.
  3. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I'm not sure about the offset housing, but everything else dyeager535 said is pretty much the way I've done it. /forums/images/graemlins/grin.gif
    Rick
