speedo goes nuts
Discussion in 'The Garage' started by sr19, Nov 21, 2005.
  1. sr19
    sr19 Newbie
    Aug 30, 2005
    4
    stl
    any one ever had there speedo just go nuts?
    like your doing 25mph and it is on 0 then 70mph
    its on 88 1500 chevy 350 tbi
  2. sr19
    sr19 Newbie
    Aug 30, 2005
    4
    stl
    just started it and the oil gauge said 0 then i turned it off then back on and it worked fine.
    this damn thing is pissing me off!!
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    If it is the electronic speedo it might be a bad ground. The oil press gauge makes me think it maybe a ground issue. My speedo is all mechanical it can only move if the cable is turning.
    Ira
  4. sr19
    sr19 Newbie
    Aug 30, 2005
    4
    stl
    its mechanical
  5. sandawgk5
    Oct 28, 2003
    6,881
    Sounds like maybe your cable is binding up and then releasing causing the errant reading or the cable is broken and catches every once in a while.
    Ira
  6. sr19
    sr19 Newbie
    Aug 30, 2005
    4
    stl
    i'll check it out and let you know
  7. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Pull the ratio adapter off of the t-case. It is coupled to the speedo gear with a pin that is square on one end and keyed on the other. They like to get rounded off on the square end, seen it a bunch of times. Worth checking.
  8. chasone64
    chasone64 Registered Member
    Dec 15, 2004
    88
    Oregon
    Also can be the cable coming out of the adapter. Mine twisted off the cable.
  9. dyeager535
    26,975
    BOUNCING speedometer will be a bad cable.
    If your speedometer just reads constantly high (or low) at times, it's more than likely the speedometer itself. It can't read any higher than you are actually moving since it is cable driven. (without the cable binding and coming loose which will cause bouncing, not long periods of high or low reading)
  10. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Hi there,
    I had the same problem on my 90 Blazer with a stock electronic speedo. It turned out that a wire was grounding out to the body in the eng. compartment. Fixed that and all is well. It would help to have a factory service manual with the electrical diagrams to trace the wires that go to the speedo. Hope this helps
    Dan..
