Speedo help?
Discussion in 'The Garage' started by coptezr, Aug 7, 2005.
  1. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    i went to the dealer sat to get a little box looking thing that goes to my t-case for the speedo.They said they cant help me i have no speedo what should i do? :confused:
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you not have one at all or ? did it ever have one or are you adding one cuz you think you have to have one ?
    is the trans case original to truck axles ratio ? gears been swapped inside it ?
    do you know that its accrate or not ?
    you dont HAVE to run one of these ratio boxes, you can just run it direct, just to make the speedo work for at least now
    if you want to check the speedo for accuracy then go ahead and connect it and time yourself at 60mph on the freeway from one milemarker to then next with a stop watch
    if you get to the next marker
    his will tell you if you need to slow up or speed up the cable rpm
    smaller driven gear will speed it up and so will larger drive gear
    tire size changes will also affect speedo accuracy,
    good luck
  3. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    You can also do the timed mile if you have a tach or another car and driver preferabbly one with cruise control time yourself over 5 miles on flat ground if possible. Look for a speedo shop or a shop that deals in custom cars they should be able to point you in the right direction
  4. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
  5. coptezr
    Jan 13, 2005
    342
    i have one in right now it just went out thursday it work with my 35's and 410's i plan on going 37's.
