Speedo inop
Discussion in 'The Garage' started by dave_90_blazer, Nov 27, 2004.
  1. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    ok, 90 k5, vss , speedo does nothing
    ok I am starting at the vss, anyone have the wiring diagrams?
    first thing I want to check is the wires at the vss
  2. dyeager535
    26,976
    Do you have access to a scanner?
    Look at MPH from the ECM, if it's not there, THEN I'd start going with specific VSS/DRAC wiring.
    Granted, I know little of the electronic speedo's and their failure rates, but checking VSS operation is easy enough with a scanner that would be the first thing I would test.
  3. duece21
    duece21 1/2 ton status
    Jan 18, 2004
    501
    Aurora, CO
    I know at my work we Ohm out the old VSS compared to a new one and if the specs don't match then we install new one. Thats the way we test them on rigs. Maybe a parts store will let you Ohm out a new one. I don't see why not your not installing it. I don't know what specs are on pickups.
