speedo noise
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by i_4x4, Mar 8, 2001.
  1. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    My speedo started to make noise on the way home tonight. The speedo head was replaced 40,000 miles ago. I was thinking the cable needed to be lubed. Should I lube it w/ a dry graphite? Or something else? Any suggestions would be appreciated.
    Thanks in advance. Ed
    LET'S ROCK
    Don't follow me you will get STUCK!!
  2. MudRebel350
    MudRebel350 1/2 ton status
    May 20, 2000
    324
    N.J.
    I think the best grease to use is white grease. That should cure the problem.
    JD
  3. dyeager535
    26,979
    Graphite acts as an abrasive, and as such should not be used in moving parts. (speedo's, locks, etc) White lithium grease should be ok though.
    Dorian
