Speedo problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by luvmud, Oct 16, 2002.
  1. luvmud
    luvmud Registered Member
    Oct 16, 2002
    6
    Seattle, WA
    Greeting from Washington State I just joined this BBS and had to post my first question. I have a 1988 6.2 K3500 that has a speedo problem, the speedo needle basically bounces all over the place or doesnt do anything at all....any idea what could be causing this?
    Do I need a new speedo gauge or? Is there any easy trick to fix this or could I install an aftermarket speedo to solve the problem?
    Thanks for any advice!
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> This is likely a problem with the cable, not the speedo itself. A new cable should fix it, or you could possibly fix it by removing the cable inner drive wire from the cable and lubing it. </font color>
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    i second that
  4. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    Easy to check the cable: just pull it out from the t-case side and look for a bent spot. If you don't find a bent spot, then most likely the magnets in the speedo head are having issues and the head needs to be replaced.
