Speedo STILL not working. What's up?
Discussion in 'The Garage' started by laketex, Mar 24, 2004.
  1. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Speedo STILL not working. What\'s up?
    I replaced the gauge and the cable, and it's still not working. What else is there? I would say something in the case, but it's failed to work through 2 different cases, seems like the concidences are a little high??? /forums/images/graemlins/confused.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
  2. 78k20
    78k20 Registered Member
    Feb 28, 2004
    53
    Eastern Washington
    Re: Speedo STILL not working. What\'s up?
    Have you checked the little "key" or adapter bit inside where the cable fits into the t-case? There is a piece about 1 1/4" long or so, roughly 1/8" square maybe that fits inside which connects the drive from gear in the case to the actual speedo cable, through a couple other connections of course. Anyway, this part is rather "soft" and over the years will wear slightly, then round itself down. Once the corners are rounded even slightly, it will just spin around, rather than turning your speedo. Only place I have found to get them is at the dealer-course mine were discontinued and no longer available, so once they located 5 of them, I got them all. Went through 3 in 5 years on an old K10 I had a while back. The newer ones that would fit your '87 are a little smaller (shorter), and are what is still used today, so you should be in luck. Price was around $15 for mine shipped.
    Hope that helps,
    Mike
  3. laketex
    6,220
    North Texas
    thanks...that had not even crossed my mind. I will explore that avenue...I appreciate your detailed reply! /forums/images/graemlins/waytogo.gif
