Speedo that compatable with factory speed sensor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90idahoblazer, Aug 9, 2001.
  1. 90idahoblazer
    90idahoblazer 1/2 ton status
    Jun 24, 2001
    183
    Idaho
    Does anyone know where I can get a new speedo that will fit in my 90 blazer dash and work with the factory speed sensor.....I have seen them in LMC but I want to know if ther is another brand
  2. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Autometer, VDO, Dakota, etc. all make electric speedos. Also many aftermarket companies and speedo shops make adapters for your application. See if there is a shop in your area or do a search on the web and I know you can find a speedo shop to help you out.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</a>
  3. 90idahoblazer
    Jun 24, 2001
    183
    Idaho
    Thanks .....has anyone out there made the conversion
  4. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    hey, check out my setup in the gallery... I've got pic's of a re-done gauge cluster with VDO gauges. <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>http://coloradok5.com/gallery/Jeffs-Stuff</a>
    you do have to prelace the sender though. (not a big deal)
    <font color=blue> Jeff - may the force be with you</font color=blue>
  5. 90idahoblazer
    Jun 24, 2001
    183
    Idaho
    Wow!!! looks really nice....did you use stock wiring and instrument bezel...I like what you have done.....if thats not a stock bezel where did you get that one
  6. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    I did use the stock bezels, and I did use the orig. wiring. I got a wiring diagram, and cut the end off the wiring harness. Next I just used crimp on connecters and wired everything up! I can get you a parts list if you are interested.
  7. 90idahoblazer
    Jun 24, 2001
    183
    Idaho
    that would be great....solo
  8. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    OK, here is the list... (summit racing part numbers)
    VDO-333160 - Tachometer
    VDO-301106 - Fuel gauge for GM sender
    VDO-332103 - Voltmeter
    VDO-350107 - Oil Pressure
    VDO-310105 - Temp Gauge
    VDO-437155 - Speedometer
    VDO-323900 - Temp Gauge Sender Unit
    VDO-360900 - Oil Pressure Sender Unit
    VDO-340011 - Speedometer Sender Unit
    if you wanna add a tranny temp gauge somewhere
    VDO-310107 - Trans Temp Gauge
    VDO-323086 - Trans Temp Sender (3/8's inch probe)
