Speedometer correction
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 6.2L Jimmy, Jul 6, 2002.
  1. 6.2L Jimmy
    6.2L Jimmy 1/2 ton status
    Jan 2, 2002
    164
    Montreal,Quebec
    Hi Everyone,
    Does anybody know what gear goes into a 700-r4 tranny
    to correct the speed difference with a truck that has 33x12.5x5 tires and 3.08 gears. Thanks in advance.
    Mike
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    there are several websites that have conversion programs to use to calculate that combination. there are two gears in your transfer case that actually drive the speedometer. sometimes you can get by changing just one gear, sometimes you have to change both. you need to know what combination you presently have. if you know someone running the same ratio, tires, you could try the same set-up they are using, if not you will have to calculate it yourself.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
