speedometer fix ???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Scott73, Sep 10, 2002.
  1. Scott73
    Scott73 Registered Member
    May 22, 2002
    38
    Electra, TX
    I have an '87 Blazer w/ 4" lift and 33" tires. I recently went from 3.08s to 4.10s and my speedometer is way off. What do I need to correct it and where can I get what I need?
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    go talk to your local gm dealer. you'll need a drive gear, a driven gear, and prob the adapter that houses the driven gear. expect about 50 bucks. you'll have to pull the back yoke piece off the t-case and it'll take about 30 to 45 minutes.
  3. 350S10NJ
    350S10NJ Registered Member
    May 16, 2002
    32
    Southern New Jersey, USA
  4. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Local Speedo Shop. They can make a converter that will correct the problem. I would plan on paying about a C-note (that was what I was told to plan on from ours here in AZ).
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I went the convertor route, and it did cost about $100. The speedo is dead on accurate though, the shop actually puts it on a chassis dyno to make sure that it's perfect. I had it done when I was running 4.10s, now that I've changed to 5.13s I'm going to have to go back and have it recalibrated. Since I already have the box though it shouldn't cost more than $30 or so.</font color>
