Speedometer gearing changed?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by blazingjesse, Apr 11, 2002.
  1. blazingjesse
    blazingjesse 1/2 ton status
    Mar 13, 2001
    159
    kayenta, AZ
    I need to find where i can buy the gears for the speedometer for my 71 blazer now that if put a 1 inch lift and 33inch tires on it.
  2. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Gears for the transfer case are hard to come by. You might be better off finding a ratio adapter of the correct ratio to compensate. One with a 10% overdrive would fit the bill, unless there's a ratio adapter already in place (you should change the adapter to a different ratio if there's already one in place).
    FWIW, my '72 with 3.07:1 gears has a 20.202% overdrive ratio adapter on it (stock). If yours has the same ratio adapter, you need an adapter with a 22-23% overdrive to replace it.
  3. blazingjesse
    Mar 13, 2001
    159
    kayenta, AZ
    yes, but where do i get one?
  4. Robin
    Robin 1/2 ton status
    Oct 30, 2001
    184
    Georgetown, Texas
    So I'm thinking about a new gauge set. Is an electric speedo (programmable) a solution (adapters available?)
  5. blazingjesse
    Mar 13, 2001
    159
    kayenta, AZ
    I don't know about a programmable one , but i just replaced my speedo , and don't want to have to buy another one, i was hoping somebody knew where i could get the adapter.
  6. Steve_Chin
    Mar 6, 2001
    1,126
    Ratio adapters are available new from GM. They cost about $50 each, so do your math and get the right one.
  7. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    how do you find out which one you have? does it say on the box thing that screws into the transfer case
    nathan
