Speedometer gears
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mr. Jimmy, Dec 16, 2002.
  1. Mr. Jimmy
    Mr. Jimmy Registered Member
    Mar 14, 2002
    63
    Haynesville Ga.
    Can someone tell me where I can buy speedo correction gears for an NP 241C transfer case. I have changed the gear ratio in the axles and would like for the speedo to read correctly.I have tried Bowtie OD, but they only sell gears that go in the transmision, not the trans case.
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    Go to a GM dealer, you will have to know what combination you need, but they can get the gears for you.
  3. Mr. Jimmy
    Mar 14, 2002
    63
    Haynesville Ga.
    I called the dealer and was told that they can only supply gears for 235-75-15 or 31" tires. I need gears for 33" tires and 3:42 ratio rear end.
  4. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    you can either get 35 and 17's or 37 and 18's. you might need a new carrier for the new driven gear. your dealer should know the split for carriers.
