Speedometer is making me nuts !
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ankarback, Nov 3, 2003.
  1. ankarback
    ankarback 1/2 ton status
    Oct 8, 2002
    294
    Huddinge, Sweden
    My speedometer doesn´t work as it should. When you drive around 30mph it shows 5mph and if you really step on it, it shows maximum 30mph.
    I´ve changed the cable and the ratio adapter for a new one.
    This weekend I replaced my transfercase (not because of the speedo) and I thought the speedo would been fixed as a bonus but it still doesn´t work /forums/images/graemlins/angryfire.gif.
    What´s left to change? Could it be the gauge?
    I´m realy going nuts about this and would realy appriciate any help I can get /forums/images/graemlins/1zhelp.gif.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    thats what i would try next /forums/images/graemlins/thumb.gif
  3. ankarback
    Oct 8, 2002
    294
    Huddinge, Sweden
    Is that a common problem? I thought that a speedometer gauge couldn´t brake because it doesn´t have any mecanical parts in it, just a magnet /forums/images/graemlins/thinking.gif
    I thínk I have to find a new one to test with.
  4. k5guyva
    k5guyva 1/2 ton status
    Oct 26, 2003
    165
    Southeast VA
    So, just replace it with an electronic one. That's what I am going to do. I am tired of greasing speedo cables and still having them snap.
    Dakota Digital makes some nice ones. They also have electronic calibration so you don't have to swap speedo gears when you swap axles or tires.
  5. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    I would go with the gauge as well. I've had speedos go bad in the past. Find a buddy who has an extra one and swap it in n see what happens. Good luck to ya.
    Allan
  6. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Screw the Speedo. Use a Tach instead, and get used to what RPM's equal what speed. Very simple....
  7. k5guyva
    Oct 26, 2003
    165
    Southeast VA
    Here is a pic of my current speedometer.
    /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
  8. ankarback
    Oct 8, 2002
    294
    Huddinge, Sweden
    I´ve thought of that too. The thing is that the car has to pass the yearly inspection and for that the speedo has to work. They are quite hard on such things here in Sweden.
    It´s a good idea though.
  9. dyeager535
    26,982
    191
    Speedo has a spring on it, some gears (for odometer), etc., so it can fail.
    Never heard of it failing like you mention, all the ones I've seen just end up bouncing around, or reading extremely fast, but that's similar enough to your problem to sound like the cause.
  10. ankarback
    Oct 8, 2002
    294
    Huddinge, Sweden
    Thanks for the help guys /forums/images/graemlins/thumb.gif
    I think I start with taking the speedo apart. When I do that I probably get some things left
    over and if I´m lucky it´s the bad part /forums/images/graemlins/rotfl.gif
    If that doesn´t help I have to find a new gauge and replace it. I let you know if I find a solution.
