Speedometer not working
Discussion in 'The Garage' started by k104salend, Sep 9, 2004.
  1. k104salend
    k104salend Newbie
    Sep 9, 2004
    3
    Im trying to get my speedometer on my 80 K10 to work so it will be more attractive to buyers. It has this aluminum cased thing on the drivers side fender thats about 3x5 inches, has 3 wires 1 vacumm line and 2 speedometer cables attached to it. Then on the T case it has a smaller elaborate thing besides just a place for a cable to hook up to. What does this do?? the cable that was from the t case to the bigger aluminum thing was frayed so my buddy removed it when he owned it then ran another speedo cable, but that didnt fix the problem of the gauge not working. Also the cables inside thing doesnt spin when the truck is moving. What could be the causes of this whole delema??
    PS tried search but could either get nothing or a couple thousand posts that had nothing to do with the subject.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    that think on the fender is for the cruise control. check both cables, they seem to go bad everyonce in a while. the only place that i know of that you can get the housing and the cable new is the dealer. you could try a junk yard tough.
    Welcome to CK5 /forums/images/graemlins/waytogo.gif
  3. k104salend
    k104salend Newbie
    Sep 9, 2004
    3
    thanks for a quick reply, this truck seems pretty bare bones to have cruise control, where did they put the on off switches?? On the steering wheel because thats not original and thats a possibility. Do all Chevy trucks with TH350s have the smaller part attached to the T case as I described or is that cruise control as well??
  4. dyeager535
    26,979
    If I understand your descriptions right, sounds like you have cruise control (the "box" that the cables go into is the transducer) and a speedometer gear "adapter" which changes the transmission output to fix changes based on tire size, or axle ratio, instead of changing the speedometer gears themselves.
    If you remove the cable from the transducer that runs to the speedometer, and spin it with a drill, does the speedo work?
    If it does, try and find the right size cable to bypass the transducer.
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    if its what i think it is its just a speedo correction box for bigger tires.
    the switch should be on the end on the blinker switch.
