speedometer problem
Discussion in 'The Garage' started by nerraw117, Aug 23, 2005.
  1. nerraw117
    nerraw117 1/2 ton status
    Jan 5, 2005
    788
    charlotte, NC
    Well i have had a big problem on getting my speedometer to work. So I have a 1979 203 transfer case that came from a truck with 3.55 gears. I swapped it in my truck with 90 wiring and a electric speedometer. So I went and got a 4 pulse VSS to plug into my transfer case. It works now! BUT when I go about 45 it reads 30. It reads 10-15 mph off through all the speed, a tad bit more through the faster speeds.
    would it be easier to take it to a shop and see if they can fix it by a gear in my transfer case and how much does that normally cost?
    or should i buy this and would this work? http://www.dakotadigital.com/index....tegory_id=287/home_id=59/mode=prod/prd126.htm btw i dont have drac or a buffer or anything just a aftermarket 4 pulse VSS
  2. nerraw117
    Jan 5, 2005
    788
    charlotte, NC
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
