Speedometer Question?
Discussion in 'The Garage' started by WakeBoard&4X4er, Jan 15, 2003.
  1. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    On a 91 K5 where is the pick up on the Speedometer? I think I was told that there is 2 of then, one on the Tcase and one on the Tranny. Is this right? On the 91 the Tcase is the 241. The Tranny is the 4L60? Here is real question, If I am Running 35s, and changing the rear Axle to 4.1 from 3.42s how will my Speedometer be off? I am not going to get it reset. Just want some ideas on how off it will be now.
    When stock 3.42s & 31s
    Now 4.1s and 35s
  2. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    I don't believe that the axle gearing affects the speedometer, only tire size. The gears don't increase/decrease the distance you get out of one revolution of the tire. So the only change you will experience will be the 31"-35" jump. Atleast that's how I understand it.
    Went from 3.42 and 32's to 4.11 and 33's, and only the slight tire size made a difference in speedometer accuracy. And AFAIK, there is only one VSS, and it's in the tailshaft of the NP241.
    Hope that helps ya out.
  3. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    " don't believe that the axle gearing affects the speedometer"
    I think it will because the drive shaft will spin at X RPM and the rear tires will turn slower then they did before. /forums/images/graemlins/thumb.gif
    But i might be wrong /forums/images/graemlins/confused.gif
  4. nofeartruckin00
    Oct 5, 2001
    798
    I could be wrong too. But none of the speedo calculators out there take gear ratio into effect. I saw a small paragraph somewhere (real helpful hey?) that talked about speedometer changes, and I thought it said something about ratio not affecting the speed the VSS picks up. Let me do some more digging for ya.
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    It most certanly does affect the speedo. If the speed sensor was on say the rim, then no there would be no change to the speedo with a gear change. But since it is in the transfer case it has a direct relation to it.
  6. nofeartruckin00
    Oct 5, 2001
    798
    Wow, put me down for an Oops! If you double your gearing, your drive shaft would spin twice as fast as before, without a tire size change. I must have been thinking about distance traveled, not speed, Sorry! /forums/images/graemlins/ignore.gif I'll go sit in the corner, maybe shut up and listen is a good idea for me...... /forums/images/graemlins/1zhelp.gif
  7. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    that is kool! just tring to get some info.
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    in the words of the infamous Marv Springer:
    "Speedo's are overrated"
  9. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Forget it! /forums/images/graemlins/grin.gif
    I havnt had my speedo hooked up for years.
  10. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    changing gears will effect it, i do not know the formula but the inacuracy is a % so it will be less of a differance at lower speeds say if it is off by 3 mph at 20 mph it could be off by 9 mph at 60 mph
  11. Storm Trooper
    Nov 24, 2000
    4,640
    You could also try this? Digital Dash /forums/images/graemlins/grin.gif
