Speedometer Question??
Discussion in 'The Garage' started by Mudbug1979, Dec 2, 2003.
  1. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    What is the name of the geared box on the side of the transfer case that the speedo cable screws into? It does have cruise and it is a th350/203tc. I unscrewed the box off the side of the TC and the little input shaft tip was broken off in the gear on the inside of the gear. I pulled the piece out and just screwed the speedo cable into it but I need to replace this part. Thanks in advance. /forums/images/graemlins/1zhelp.gif
  2. Mudbug1979
    Aug 4, 2002
    439
  3. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i forgot technical name of them also but they are to fine tune the accuracy of the speedometer gears ratio because with soem axle ratio and tire combos there was no pair of speedo gears that were completely accurate and in most combos they never are anyways, but they are real close though.
    most of us probably have a few of these speedo gear boxes laying around, i know i do.
    good luck
  5. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Sounds like your gear drive key broke. Chevy part # 867209 $12.81. The key is about 1.5 in. long. One end looks square thje other has an ear on it. I had a piece stuck in the gear drive box. Drilled it out and then installed the new gear key.
