Speedometer won't read Zero!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Toad, Aug 19, 2000.
  1. Toad
    Toad 1/2 ton status
    Mar 15, 2000
    157
    Utah
    Speedometer won\'t read Zero!!
    My speedometer doesn't go down to Zero! Dang thing stops about 10. Stops going over 50. It goes back to Zero if I drive it in reverse. I saw someone else had this problem. What will fix this?
  2. dumbfounded
    dumbfounded 1/2 ton status
    May 20, 2000
    176
    Castalia, NC
    Re: Speedometer won\'t read Zero!!
    Speedometers do wear out and unless its like a shakey needle (usually the cable needs lube) just go to a junk yard and pick up a dash assembly. They are pretty cheap. As for fixing the actual guage good luck small parts and no parts to fix just swap. You may be able to swap the odometer if you are careful.
    Love, Peace, and Hair Grease...........
