speedometer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dpearson, Apr 11, 2000.
  1. dpearson
    dpearson Registered Member
    Apr 10, 2000
    95
    El Paso, TX
    How do you go about recal. your speedometer. Do you need a different gear in the transfer case?
  2. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    You need a differnt gear in the speedometer housing on your trasnfer case. A while back in peterson's they had an article about changing the little gear sizes. Im still holding off because of going to a different size tire (larger)
    <font color=purple>79' K-5 396cid 600hp, TH350, NP203</font color=purple>
    http://79blueknight.homepage.com
  3. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Gm has eather 5 or 6 gears that goes in the transfer case that changes the speed seating in your truck. You can also go to a speed shop that does speedometers and they can put a box that is adjustable to correct it.
    C'moe
    <font color=black>the blazer is "Back in Black"
