speedometer??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mud Bath, Aug 30, 2000.
  1. Mud Bath
    Mud Bath Registered Member
    Aug 28, 2000
    84
    Wake Forest NC
    My speedometer reads 15 mph fast. I swaped from 2.73 gears to 3.73 gears. I also run 33" tires. Its really spinning the miles on the odometer how can I get this fixed with out taking it to a shop? Any suggestions?
  2. Scoobydoo
    Scoobydoo 1/2 ton status
    Jun 9, 2000
    244
    Phoenix / Peoria ARIZONA. (75thAve/DeerValley)
    Put 38" tires on it[​IMG]
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    The gear is in the t-case. I think each tooth=2mph, so just add or subtract teeth as necessary. You can get the gear at the dealer. Not sure exactly where on the t-case it is though.
    [​IMG] Sept 1
  4. jimee
    jimee Newbie
    Aug 30, 2000
    I had a similar problem. I found a great parts guy at a local chevy dealer. he found me the right gears to get my speed right on. Also the gears are located in the tail housing of the transfercase. Where the cable conects to. There is a drive gear and a driven gear. Hope this helps.
