Speedomotive Stroker Kit
Discussion in 'The Garage' started by earlthek5, Nov 4, 2004.
  1. earlthek5
    earlthek5 Registered Member
    Aug 25, 2004
    12
    Has anyone ever heard of www.speedomotive.com? I was looking into one of the 383 stroker kits, and was wondering if anyone knew if the parts were junk or worth it. Seems like a deal? Here is the stroker page link...
    http://www.speedomotive.com/CHEVY%20STROKER%20CRANK%20KITS.htm
    On the link, which 383 kit (2-piece seal) would you order for general offroading with occasional high rpm? Thanks in advance.
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
  3. earlthek5
    Aug 25, 2004
    12
    Would I gain anything by going to the full forged kit, or would that be looking for trouble?
  4. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    I would stay away from the kits speedomotive sells. When I looked at kits for my 383, speedomotive was at the top of my list. After putting more research into it, I found that the Eagle and Scat cranks that speedomotive (and many other bargain stroker kits) sell are made in Korea and are notorious for causing problems. I ended up using a forged crank out of a 400 that had been turned down for 350 bearing journals that I bought from my machine shop for $275. I used the Keith Black hypereutectic dish pison kit (~$520 I think, including gaskets, rings, bearings, etc.) with 64cc vortec heads. I had my stock 350 rods reworked and used them. All in all, I probably have about $950 into the equivalent stroker kit that you are looking at. That is the way I chose to go, having a crank go bad on you (which I have heard about multiple times with Scat and Eagle) is not something you want to deal with. Trust OEM GM stuff /forums/images/graemlins/thumb.gif
  5. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    My 383 was a Speedomotive kit when I built it back in '89. I havent put too many miles on it (maybee 5K tops). Back then they were really good to deal with.
  6. sandy78
    sandy78 Registered Member
    Nov 28, 2002
    84
    Utah
    I used one of their kits w/ their crank, 5.7 rods, and a cast, reverse dome piston. I am running Vortec heads, performer intake, and a q-jet. It runs great, no problems with any of the parts. I would say that no matter who does the machine work, you should always double check the journal sizes. Mine turned out to be slighly under factory spec for a standard crank so I ran .001" under main bearings (it means the bearing is slightly thicker to reduce clearance). Also, no matter what, get a brush and clean the oil passages with some solvent. When you assemble, check all your clearances.
  7. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    Speedomotive is one of the oldest "mail-order" performance parts companies around. Back-in-the-day (before the Internet) "mail order parts houses" is what we called companies like Speedomotive or Performance Automotive Wholesale (PAW). Can you believe we actually used the U.S. Mail in those days to deliver parts from large speed parts retailers? Doug Herbert (who drives the Snap-On sponsored Top Fuel Dragster) is another person that is big in the on-line performance business. His Father, Chet Herbert, was the pioneer of "Mail order" performance part houses.
    http://www.dougherbert.com/
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    What's wrong with U.S. Mail?
    JC Whitney ships almost everything they sell parcel post. /forums/images/graemlins/confused.gif
  9. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    Nothing is wrong with the U.S. Mail, if you do not mind waiting 7 to 10 business days to get your parts, which was normal back in those days. /forums/images/graemlins/histerical.gif
  10. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    ...yeah, ask my buddy about Speedomotive... He bought a 383 from them and had it installed at a mechanic shop w/ Vortec heads, Airgap intake, Qjet, and headers... Didn't make that much HP and at about 3000 miles a piston and rod came apart and ruined the ENTIRE engine... block, crank, cam, etc... all destroyed. He called Speedomotive, and they basically told him to piss off.
    Long story short...I wouldn't recommend them to anyone for anything.
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I was just looking at Jeg's website and they have a few rotating assembly kit for the 383 stroker by Eagle Specialitys. Jeg's
  12. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    One thing I have learned over the years is when it comes to assembling and putting a new engine into your personal vehicle CORRECTLY, no one can be trusted, but yourself (if you are an experienced "wrench"). There are many big egos in the automotive business that would never admit this, but if the money is not theirs, they do not give a sh!t. There are too many details, when it comes to doing and engine assemble and R&R, that can (and will) be over looked by the mechanic with even the slightest amount of "it is not my money" attitude.
  13. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I've never dealt with Speedomotive but you'd think that a guy who runs the fastest piston driven motor on Bonneville would know a thing or two about putting together power packages.
