spendin' money,need help!
Discussion in 'The Garage' started by jones, Mar 18, 2005.
  1. jones
    jones 1/2 ton status
    May 17, 2004
    379
    IONIA,MI USA
    with the main goal being torque,then HP,what would you do first?i don't want to pull the engine for a bore job just yet.i'm already running an E-BROCK Performer manifold and 500cfm carb.thats about it.the rest is a basically a stock 350,camel-hump heads,stock manifolds,and distributor.throttle response would be a good thing since it's quite the dog(but reliable at least).$1000 is the budget.all opinions are appreciated and anticipated.thank you!
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Headers would be a good start, and you could probably go with a little more than 500 CFM.
  3. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    You could throw in a edelbrock performer cam kit, or maybe the Comp Cams 4x4 cam. Or you could just get the performer heads.
    Later
  4. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    What diff gear ratio/tire size do you have? Maybe lower gear set and some headers.
    Jesse
  5. jones
    May 17, 2004
    379
    IONIA,MI USA
    i have 4.10's w/ 31-10.5-15's.i have headers that came with the engine but i think they're for a car.can i still use them?i also plan on going with a q-jet carb.and i can get my cam installed for cheap."rv cam and lifter set still in box.not sure of specs but it's one step above stock."that's what a guy told me about a set he'd sell me for $20 cuz he's tired of moving it around his shop when he cleans it.i told him i,d be interested if it looked in good shape and he had the cam card to show lift/duration.
