Spicer 1/2 ton hub interchange?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dyeager535, Mar 31, 2001.
  1. dyeager535
    26,979
    Curious as to whether there is any reason the Spicer manual hubs say off a 1970's truck won't work on an ex-auto hub axle? I put a set of these on my truck a long while back, and never did get a chance to test them. So of course tonight, when I need to turn my truck around, without the rear driveshaft useable, I put it in 4wd, lock the hubs, and proceed to let the clutch out. Got the familiar "whirring" noise my auto hubs used to make, but no forward movement. I checked the center twist piece, and I could shove it in a good 1/4 inch. I think somehow I jsut assembled it wrong, but it was starting to rain as I was pulling it apart, and I didn't have the manual handy. Were the same manual hubs available from the 70's used on the '81 up 1/2 tons, or was there a universal change one year to auto hubs?
    Dorian
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    You may have them assembled wrong. I have done that with my spicers before.. Sucks having to take them apart again!
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    "He who uses a winch...... Is tired of yankin!"
  3. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    The hubs are interchangeable, also between Chevy/Dodge/Ford.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
