Spicer P/n for 35 spline stubs
Discussion in 'The Garage' started by 84_Chevy_K10, Jul 1, 2004.
  1. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Anyone have it?
  2. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    35 Spline Stub: D382871
    GM Short Inner: D660182-5
    GM Long Inner: D660182-6
    4WD Factory has them cheap or I can get them for you at same price.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I am a vendor I just needed the p/n to order a set, thanks. /forums/images/graemlins/thumb.gif
  4. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    Transamerican?
  5. sidslc
    sidslc Registered Member
    May 27, 2002
    96
    slc ut
    you will need to do some machine work to the ends of the stub shaft to make them work right and not destroy your locking hubs.
  6. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    I dont think that is true anymore with the new Warn hubs.
  7. BlueBlazer
    Feb 15, 2001
    1,940
    You're a vendor but had to ask on here for the part number /forums/images/graemlins/thinking.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I couldn't find it. I'm a parts guy and I couldn't read a catalog, got any more low blows?
    I actually found the part number not five minutes after I posted this......
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'm not using hubs. Hubs with 35 spline outers seems like a not so good idea in my opinion.
  10. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    That was true for the Warns designed for full float rear applications part #38786. The part #62672 work just fine. Warn #39346 drive slugs work even better.
  11. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Why do you say that /forums/images/graemlins/thinking.gif
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Exactly. /forums/images/graemlins/thumb.gif
    The 35 spline upgrade has become popular now. In the beginning it started with some guy saying, "Wow, look at this P/n, wonder if it'd fit in here."
    It has now cought on to hte point that every major hub manufacturer has joined the party. /forums/images/graemlins/thumb.gif
  13. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The 35 spline hubs are known to be kinda weak and become a failure point. When you upgrade to 35 spline with hubs you move the brakage point from the stub shaft to the hub (assuming you run non necked down inners). Drive flanges are stronger then hubs.
    Harley
  14. BlueBlazer
    Feb 15, 2001
    1,940
    IMO I would want the hub to be the weak point, thats part of the reason I went with hubs, also I can unlock them for street use of course.
  15. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    But with slugs, you have 4 wheel all the time, won't that get annoying when trying to turn in a tight spot?
  16. BlueBlazer
    Feb 15, 2001
    1,940
    Its not really a problem having slugs unless you have a front locker.
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I prefer not to have a weak point, shock loads from axle failures are known to break locking differentials among other things.
    I don't drive my rig on the street anymore but if I did I would have no issues with doing so even locked up front as long as I did it in 2wd. Without input torque my locker doesn't seem to want to lock up, and my high angle driveline can more than take highway speed even at the angle it is operated at.
    This is an endless debate but I feel that the slugs are a better choice for the 35 spline outers.
    My truck hasn't been out of 4 low since I bought my trailer so I suppose it's not going to matter anyway.
  18. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Yeah, when you have a front locker then its hard to turn.
  19. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Not if you have hydro assist steering. I run the WTO Redneck Ram, and a Deee-troit up fron and when I was stuck I was sawing the wheel back and for at about 4 grand RPM and didn't have single issue with steering.
  20. BlueBlazer
    Feb 15, 2001
    1,940
    If you are using Spicer stubs, they WILL be the weak point. With hubs, the stubs should last. Now if you had some higher dollar stubs with slugs, you shouldn't really have a "weak" point, just a matter of what point is weakest.
