Spicer u-joint question
Discussion in 'The Garage' started by Thumper, Mar 14, 2005.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Hey, I just recieved my 5-760x u-joints for my chromo shafts. Well, I pull them out of the box and this little paper falls out that says: "Spicer Pre-Lubed Light/ Medium Duty U-Joint"
    Now... I ask myself... why is it that these things are so big on everyones list as being very strong, but they only say they are light/ medium duty? The other brands (Precision) are called "Extreme Heavy Duty". What gives? Did I get the right ones? Is Spicer just playin with the other manufacturers by saying that thier light/ medium duty joints are actually tougher than the competitions Extreme duty ones?
    Just curious! :)
    Mike
  2. sweetk30
    Nov 1, 2004
    25,540
    539
    horseheads , ny 14845
    thay are pre greased from factory and thay arnt big rig joints . are little trucks are light/medium duty trucks.
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Our rigs are meduim duty next to a mack. Order a driveline joint for a peterbuilt, and you will see needle bearings the size of magic markers.
  4. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    the bearings arent that big but they are huge. i went to a truck parts store (big rigs,ligth duty etc) and they had a u joint on the table. the cap was about as round as a pop can. the drive shaft that goes between the 2 rear axles weighs a ton. i asked the guy if they made and adapter to fit those on my blazer. he laughed and said no but if they did he'd have some on his truck.
  5. Thumper
    1,582
    Alberta Canada
    Well, I know that ours are classed as light/ med duty. But Im sure that Precision also makes a big rig joint too, so why are thiers called 'Extreme Heavy Duty'? Id think that Spicer would want to call thiers something macho just for the sake of image? :)
    Mike
  6. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Either way, I run the 5-760's and beat the piss outta them and theyve held up fine
  7. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Spicer already has the rep and the market share, so no need to play word games.
    Precision uses those terms because they're probably trying to gain market share, even though their U-joints suck IMHO.
    The worst U-joints I've had were Brute Force and Precision.
    Rene
  8. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    You must not have seen my post with the Spicer U-joint ruler on it.
    A "heavy-duty" Spicer U-joint for a heavy truck (i.e. Peterbilt, Kenworth, etc) makes a 1350 look like something off a kid's toy. Too bad the yokes they use are so beefy that there's not much angularity possible...
