Spider gear Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Redfrog, Jun 28, 2001.
  1. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    How big of a pain is it to change out spider gears in a 12 bolt?
    do I need any special tools? I does not look very hard but I
    would like to know what I am going to get me self in to.
    HEY Fords!!! how many flushes does it
    take to get rid of you
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Easy--call Jeg's, get a Lock-Right, and pop it in.
    Tim
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    FYI, there is one bolt that is very very important, I call it the "cross shaft retaining bolt".
    Make sure you understand the perpuse of that bolt.
    Tip...... make sure you use the right tool to remove it, and for future use try to measure the tighten torque.
    Good luck
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    It's very simple to change them. The question is why are you changing them? If they're damaged, there's a 99.999% chance so is the ring and pinion.
    <A target="_blank" HREF=http://fwp4x4.rockcrawler.com>http://fwp4x4.rockcrawler.com</A>
  5. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    just weld them...
    1974 Chevy Blazer Cheyanne. lots of plans for it....
    but it is on 33's now, with saggy old springs. i am in so cali if ya got any parts for me.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That'd work!
    Tim
  7. Redfrog
    May 4, 2001
    753
    IL
    When I bought it I was told the gears were new I knew the guy
    real well so I'm pretty sure they are . the reason for replacement is when parking on a incline and taking my foot
    off the brake it rolls foward and I here a nasty "clunk" for lack of a better word and I can feel it in the floor. I took it to a guy that has rebuilt axels for a long time and he said that it was the spider gears.
  8. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Pull the cover off and take a close look at all the gears. They shouldn't be pitted or scarred. The diff oil probably needs changed anyway. If there's dirt in the diff or the oil is light brown, the axle seals are bad. You can do this inspection very easily, without disassembling anything. It may not be in the rear end. Sounds like the parking pawl in the tranny if it's an auto.
