Spider gear switch
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlueBlazer, May 13, 2001.
  1. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Im wanting to get a 12 bolt rear for my truck and I want to take the lock right i have in my 10 bolt rear and move it to the front til I get the new axle. I need to know if the lock right will move right to the front with no problems and also can I move my front spider gears to the rear and have everything work ok. I know that the front doesnt have c-clips and the rear does so im worried it wont work. It will be a month or two til I can get a 12 bolt, so I would like to save the wear on the lock right and I was going to move it up front anyway. I appreciate any help you guys can give me.
  2. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    It'll work.
    I believe the difference in the front and rear Lock Rights is that the fronts don't have the teeth cut out to accept the c-clips.
    Stick it in there.
    Lift It, Lock It, LIVE IT!!!
  3. BlueBlazer
    Feb 15, 2001
    1,940
    Will the spider gears swap without a problem. Id use the old ones but they were grenaded from a full throttle powershift (dont ask). Thanks again for any help.
    '82 K5 6.2 Diesel, sm 465 np 205, 35" muds
  4. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Full throttle powershift!?!? What in the world were you doing? Showing off?
    SK-15
    J**P...it's whats for dinner!
    <A target="_blank" HREF=http://SK-15.coloradok5.com>http://SK-15.coloradok5.com</A>
    Roads? Where we're going, we don't need any roads!
